16v into 85.5 woes, no spark, no tach bounce, starting to lose my mind...
Figured I'd see what you guys have to say about my no spark 16v swap. I've done a ton of troubleshooting since I first started battling this...
Car is an 85.5 NA 8v, in which I swapped an '87 16v motor, harness, flywheel, ecu, ICM. No Spark, no tach bounce. It seems that the ECU is not sending any signal to the ICM to drive the coil. I can fire the coil via the ICM manually by grounding out the pin 1 on the 14 pin connector by brake booster. Reference sensor tests good, and I have swapped in a known good one from my 8v just for grins with no change. It was gapped too high initially, manual calls for >3v AC while cranking- it was more like 2.2v, after gapping it jumped to like 7.xx volts. This is at the stock .8mm gap specified in the manual. Not totally sure what that means. I do have a new reference sensor on order that will be here in a couple days just to completely rule it out. I also have a new ICM on order, though by all counts it seems to be functioning as it should. ECU is firing the injector harness- I take this as another indicator that the ECU is receiving the proper information from the reference sensor, but maybe I'm wrong. Injector harness stops firing with the reference sensor unplugged. All this pointed me in the direction of a bad ECU. I tried another secondhand ECU today, no change. There obviously is a possibility that they're both bad but I pretty well doubt it. Any ideas here? |
Possibly alarm wiring or Ignitor (ignition module).
https://members.rennlist.com/tholyoak/944_engine_swap_wiring.htm 944s2 3,0 engine wiring
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
SLED GUITARIST
Dme relay?
1988 944S Guards Red---Hers FRWilks Chip, MSD Blaster 2 1987 944S Blue Diamond Mine Crankscapper, MSD Blaster 2 Coil, Weltmeister Race chip, Sports pack. Hit by a sleeping driver at 2pm, soon to be the Black and Tan 1985 944na Gray---His Eibach Gound Control Struts/Koni Rear, Throttle Response cam. SOLD
Those links have proven exceptionally helpful, especially as I was confused about the ICM wiring. |
DME relay shouldn't be a factor if the DME is lit and the fuel pump runs. But a jumper wire alternative is nice for troubleshooting when nothing seems to make sense.
Alarm wiring is in play if there is a need to jumper pins or connect the S2 DME to the alarm brain to satisfy the disabler, I do not recall the details of this but I have a shiny nickel that says it's different from an 8V. -Joel.
Can anyone confirm the actual activity during cranking (or running, for that matter) at the ecu pin 1/pin 1 at 14 pin connector? (ignition pulse to final stage) I'm just assuming it's a pulsed ground to fire the ignitor but I don't know for sure what to look for....
Holy frickin smokes, it lives. Turned out to be a bad ICM. Wish I hadn't troubleshooted the entire system for a week....
Now to find out why it sounds like I have no oil pressure in the top end.... |
