944 1986 heater valve leaking
Hello I need some advice on draining the coolant from a 944 the top end hose so I can replace the leaking heater valve. I don't want to have drain the completed system right just the top end and remove upper hose or do just drain from the side radiator valve. also I can reuse the coolant IT S STILL GREEN CLEAN THEN FILL IT BACK UP BLEED SYSTEM.
Thanks for your help!
Old 10-17-2020, 01:45 AM
Just spend the 15 bucks and do it right.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 10-17-2020, 03:07 AM
Ernie944's Avatar
+ 1 George......... first flush cooling system with an HD Aluminiun radiator flush....then get a Phosphate -Free 50(50 mixe anti -freeze such ....see picsLike George mention do it right the first time & you won't have no comeback.Take care
Caraquet,N.B. Canada.
Old 10-17-2020, 02:28 PM
