What's up, I have an 87 944s and I'm having a couple of issues. When I bought the car I didn't know it had several different injectors in it... it actually had one injector for a turbo model and one for a 928. The wrong injectors caused a misfire, So I've now replaced them with remanufactured genuine Porsche injectors. However, the car is now running lean. I've put sea-foam through it once to try and clean all of the old gunk out. after I did that I inspected the injector wires and I've replaced them all. the car runs and drives with no problem but it is definitely running lean. I replaced the coil, and the cap and rotor and the wires. The only three things I can think of that would cause the car to run lean are, a.) timing, b.) o2 sensor, and c.) the DME?
What is your fuel pressure reading?
If good, then your coolant temp sensor might be bad. Maybe a bad ECU.
Good luck, George Beuselinck www.944ecology.com Porsche Deconstructor (tm) We buy 944s and sell 944 parts (845-379-1944) We rebuild torque tubes and instrument clusters for 944/968/928 |
Kessel run in 12 parsecs!
Have a porsche dealer check it out, the can do a diagnostic on it and see whats up..
Keep cool man.. ![]() |
In the Fires of Hell.....
Vacuum leak?
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost 1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th 1987 944S - Restored salvage title, ready to live again I can fix your late 944 Cruise Control module - PM for details |
how are you so sure it is running lean?
do you have a wideband O2 hooked up, or is it failing smog? |
Thread Tools | |
Rate This Thread | |
Tags |
lean fuel , spark plugs , timing belt |
