Sunroof
(86' NA)I know that there has been a lot of stuff posted on sunroofs and I have read all of them that are on this bb. I dont have a owners manual and I read that there is a manual crank. Can someone tell where it is. I know it is in the back somewhere under some carpet but I cant find it. Also does anybody know where there is a shop manuals on the internet? Any help would be appreciated.
Old 08-31-2000, 04:02 PM
Banned
You will find the sunroof stuff on the left side of the rear. To get past the carpet, you will need to remove the plastic "push-in" button's.
Old 08-31-2000, 04:07 PM
I bought an owners manual from these guys and saw that they had good prices on manuals http://www.my-porsche.com/
Thom
Old 08-31-2000, 07:05 PM
Are talking leftside as driver side or left side as passenger side.
Old 09-01-2000, 06:16 AM
hoff944's Avatar
Send a message via AIM to hoff944
Driver's Side. You can only raise and lower the roof with this. You can not remove it.
Old 09-01-2000, 07:05 AM
Great. I found the sunroof crank. My sunroof obviously doesnt work. Where should I start to look for breakdowns in the system. I am not much with cars put I can use a wrench and think.
Old 09-01-2000, 08:54 AM
I pulled the sunroof switch from the console right in front of the shifter. How do I check to see if the switch is good?
Old 09-01-2000, 05:33 PM
hoff944's Avatar
Got an Ohm meter?
Old 09-01-2000, 10:21 PM
Under the motor there is a place where it looks like there should be relays. Can someone tell me if this is correct. The only sunroof relay I have is the one in the fuse box.
Old 09-07-2000, 06:07 PM
