-   -   Fuse troubleshooting (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/10800-fuse-troubleshooting.html)
fdb70 08-29-2000 01:58 PM
Does anybody know where the driver side headlight (DIM) fuse is located. My Dim light doesnt work & I suspected the fuse is the culprit. I have an '85 944. Pls. advise.
Lawrence Coppari 08-29-2000 03:09 PM
Isn't there a fuse/relay box right in front of the driver. There is a paper glued inside that says what each fuse/relay is for. I am assuming 85 is like 86T. This is under the hood....
[This message has been edited by Lawrence Coppari (edited 08-29-2000).]
rben 08-29-2000 03:59 PM
If your 85 is an early model, the fuse box
is under the left side of your dash. If you
have the 85.5 the fuse box is under the hood,
as Lawrence states.
fdb70 08-30-2000 05:58 AM
Mine is an '85 944. I saw the fuses but there are no indications on whether which one is which. Does anyone know which fuse is for the driver side DIM headlight?
Thanks,
Fdb
p0r2chby 08-30-2000 08:20 AM
Hey, if it's a single side problem, perhaps the bulb is to blame. If I remember, the headlights have a dual element thus, you could have one of the elements out. I have never seen a car that has a separate fuse for each headlight. You could swap bulbs from side to side to test for this. If you do end up needing new bulbs, replace both sides at the same time...
fdb70 08-30-2000 10:50 AM
I already did replaced the bulb & still no result. That's my next suspicion is the fuse. Do you know which fuse to replace?
Cebu 08-30-2000 03:45 PM
85.5 944..Headlight fuses: 20=L-highbeam
21=R-highbeam 22=L-low & 23= R-low These fuses are down the left side of the fuse box facing forward, parallel with the left fender.
fdb70 08-31-2000 01:57 PM
Cebu, mine is an '85. Is it the same fuse location as your 85.5?
fdb70 09-01-2000 05:45 AM
early '85(old dash board).
fdb70 09-01-2000 11:25 AM
Thanks Shaun for the detailed info. I'll crawl under the dash tonight.
fdb70 09-05-2000 05:52 AM
FYI - I replaced the fuse #1 located at the lower bank but no result. Any other suggestions?
lm6y 09-10-2000 07:01 PM
Take the fuse in question out, and clean the contacts on the fuse box with sandpaper. I had a similar problem, and this fixed it. Hope it helps.
fdb70 09-11-2000 11:02 AM
I noticed the contacts of the fuse are corroded. I will try the sandpaper & will let you guys know. I appreciate your thoughts.
Fred
