Sunroof help please!!
I looked today for the switches on the sunroof motor that lock the roof down...they are there, but they are just hanging...does anyone have a picture of how they should be set up? Thanks guys.
Old 04-25-2003, 05:40 PM
ttt
Old 04-26-2003, 04:57 AM
overkill's Avatar
Send a message via AIM to overkill
They should be bolted down with little nuts and bolts. They might be stuck to the side of the sunroof motor seeing that it is magnetic. On of the switches is to tell the car when the sunroof is closed and the other is to tell the car when the sunroof is detatched. You have to setup them up so they trigger just right. I'm going to find this site that explains it in detail,... brb.
{1987}944S - (SOLD).
Old 04-26-2003, 05:10 AM
overkill's Avatar
http://www.pelicanparts.com/techarticles/944_Sunroof/944_sunroof.htm
Old 04-26-2003, 05:25 AM
I understand the concept, but like I said...my microswitches are not bolted...they are hanging...so I need a picture of a working one so I can know where and how the microswitches bolt on.
Old 04-28-2003, 07:42 AM
944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
What is your car type and year??
944S Boyeee
1989 928S4 Canadian Edition
75,000 klms
Old 04-28-2003, 08:05 AM
overkill's Avatar
Well, the 944S switches(don't know if they are different), theres 2 little bolts that pass right through the switches and the motor thing. You tighten them until they do what they were designed to do.
Old 04-28-2003, 08:22 AM
it's an 87 turbo...I know you tighten the screws... there are NO SCREWS...the switches are hanging...I need to know where to put them back on
Thanks guys
Old 04-28-2003, 01:10 PM
ttt
Old 04-28-2003, 08:20 PM
If you look at the motor from the top, you should see a hole in it towards the top center. As the motor spins, you should see a white plastic piece moving behind this hole. It's that white plastic piece that hits the switches.
The microswitches are fixed just above this hole. They screw/bolt onto the motor assembly itself. There should be two small holes on what should look like a "ledge" that these switches sit on.
944S Boyeee
75,000 klms
Old 04-29-2003, 05:53 AM
