-   -   Dash light fuse blowing (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1080630-dash-light-fuse-blowing.html)
cfassett 12-12-2020 08:35 PM
Hi all!
Got a question. Since I’ve had my ‘86 951, the fuse for the dash lights blows immediately when I turn on the headlights. The dummy lights all work fine. The issue is the fuse for the backlighting. Thought I had this fixed when I required the headlights, but was wrong.
Has anyone else had this issue? Wondering if there’s a common cause for this.http://forums.pelicanparts.com/uploa...1607834183.jpg
944 Ecology 12-13-2020 04:43 AM
What is the fuse number that is blowing? If you disconnect the instrument cluster, does the fuse continue to blow? Do you have a wiring diagram for your car?
cfassett 12-13-2020 06:28 AM
Thanks for the guidance. This is fuse 38 “instrument lights.”
I disconnected the 2 cluster pigtails this morning, and it still popped when I turned the lights knob. Without the key in the ignition.
cfassett 12-13-2020 06:39 AM
Following this, also disconnected the pigtail to the headlight motor, and then the plug to the drivers headlight. Still popped each time.
944 Ecology 12-13-2020 06:44 AM
fuse 38 also feeds the license plate light.
cfassett 12-13-2020 07:16 AM
Interesting. When I bought this car, I recall the dash lights worked on the drive home. It also had one of those big aftermarket PORSCHE taillights, which I quickly pulled.
Found that on the license plate lights, one of the wires was grounded to the floor of the trunk. I cleaned up the wire connections on the lights and disconnected this wire from the ground and the fuse survived. Are the license plate lights supposed to have a ground like this?
http://forums.pelicanparts.com/uploa...1607872549.jpg
944 Ecology 12-13-2020 07:58 AM
The brown wires are the ground for the license plate lights. The non-brown wires are not from the factory.
cfassett 12-13-2020 10:05 AM
Thanks for your help! Had a positive wire connected straight to ground. Don’t ask me how it happened.
Crazy how I’ve struggled with this for almost a year, and with some help from NY, it seems that this issue was fixed in a few minutes this morning!
944 Ecology 12-13-2020 10:25 AM
It helps to have the factory workshop manual and the wiring diagrams.
mytrplseven 12-15-2020 11:23 AM
When I got my car back from having a complete disassembly and repaint, I had similar issues. I eventually had to disconnect all the exterior lights and found the reassemblers had not connected the side lights properly and was shorting everything to ground. Great paint job, though.
