Battery cables
Hello, how is everyone? I have a question about the battery cables on a 1987 944 turbo. Can anyone tell me the lengths of the positive and negative wires? Porsche wants to much for them and I am hoping to get a set that is already made up. Any help would be greatly appreciated! Jrmongo@verizon.net
Old 02-17-2021, 04:38 AM
Sorry don't know the lengths. Are they missing on your car? If you don't want to spend the money on new cables you could find some used ones.
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 02-17-2021, 08:54 AM
https://www.ebay.com/itm/Porsche-924S-944-944S-944S2-951-944-Turbo-and-Battery-Cable-Set-NEW-/274460800149?_trksid=p2349624.m46890.l49292
This guy makes really good quality stuff, very happy with mine.
Old 02-17-2021, 09:48 PM
A lot cheaper alternative:
https://www.batterycablesusa.com/0000-gauge-4-0-awg-extreme-battery-cable-with-ends
Good luck, George Beuselinck
Old 02-18-2021, 03:41 AM
.... or “good used” from someone like Plyhammer’s or John Graves/JustJoshin’ ? With my 87 924S, I cleaned all the ends very carefully and did re-wrap some cracked insulation.
John
Old 02-18-2021, 08:18 AM
Cleaning the ends only does so much when the wires are corroded all the way through. I'll take some pictures of my stock ones if I can remember to.
I replaced my battery, starter, and alternator wires with the ebay kit. Everything was cut to the proper length and I even got the starter end customized to fit my high torque starter. Install took only a few hours.
Old 02-18-2021, 08:41 AM
Indeed. I’ve seen cables corroded by wicking battery acid, 90’s and 00’s Volvos, early MINI’s etc. But older cable doesn’t necessarily mean bad cable.
John
Old 02-18-2021, 03:04 PM
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 02-18-2021, 05:48 PM
Soldering new lugs on the end of the cable could do the trick.
Old 02-19-2021, 07:40 PM
a few months ago i replaced the battery->starter cable on my 944 with an $8 replacement (6 ft?) from the auto store. probably light on the wire size but its a nice weather weekend car only.
look how corroded the original cable was!
Old 02-20-2021, 08:14 AM
use your old length and make them out of real copper. the number of strands is inversely proportional to the current capacity for the same gage.
https://www.batterycablesusa.com/UL-flex
Old 02-21-2021, 08:04 AM
