Lost oil pressure on freeway
Engine started running a little rough, oil pressure gauge was on zero so I turned the car off and coasted to the side of the road. There’s still oil in the engine, might be low but it was full this morning and there’s no sign of a leak. Tried to restart and it started briefly, oil pressure made it to the top of the gauge then dropped back down to zero and the car shut off. First time the 944 has put me on the side of the road
![]() Any guesses? Thanks! |
Left out a critical bit that there’s charging light on the dash started flashing right before we shut down. I’m suspecting an electrical issue or maybe serpentine belt tension too loose after driving for hours
In the Fires of Hell.....
Sounds electrical to me...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
running rough and no oil pressure makes me think it's a rod bearing
2002 Porsche 911 turbo 2007 Porsche Cayman S track car 1987 Porsche 924 Carrera GT tribute 2015 BMW X5 |
The belt drive system could be affected by a loose crank bolt, which would also kill oil pressure.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
Its usual for the charging light to flicker when the engine revs drop and it’s about to stall. If your oil level is now low and it was full when you started off this morning like you said, then you are losing oil from somewhere so check around for leaks. If you don’t see any external leaks then there may be oil in your coolant or in your combustion chamber. Check for milkshake in your reservoir and oil on your plugs.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Do you hear a rapid, pronounced tap that increases or decreases with engine rpm? (spun bearing) Other than that, it could also indicate an issue with the oil pickup tube, or faulty oil pump/oil pump drive gear (rare on these cars). Best case scenario its just a bad oil pressure sending unit. I would test the existing one, or replace with known working unit and see what happens.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP Last edited by walfreyydo; 02-22-2021 at 02:40 PM.. |
“There’s still oil in the engine, might be low but it was full this morning” Please explain how would rod bearings, oil pickup tube, oil pump or oil pressure sender be the cause? ...Maybe I’m missing something, or we need to know how low it is compared to it being full earlier that day, idk.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. Last edited by 9FF; 02-22-2021 at 02:52 PM.. |
He actually never confirmed if it was low, (said it might be) but that would be good to know as a first step before moving further.
Anytime you have low oil pressure scenario its either a false reading from the sender, low oil, or some internal mechanical issue- such as an issue with the oil pump itself, oil pickup, etc. 1) Bad oil sending unit would (obviously) not be transmitting the correct pressure to the gauge in the dash, leading one to believe a false reading of zero pressure on dash. 2)The rod bearings themselves act as a restriction which (intentionally) keeps oil pressure high, due to the small hole which the oil flows from the crank journal onto the bearing surface. When that restriction is removed, such as when you spin a rod bearing, or bearing clearances are too high (for many reasons), oil pressure drops because there is no longer that bearing as a restriction. This restriction is necessary to keep the oil pressurized as the oil pump needs something to pressurize against. 3) Oil pickup tube crack should be self evident as to why you would lose oil pressure (try to drink something with a hole in your straw) 4) Oil pump or oil pump drive gear stripped = not pumping oil, nuff said. Crank pulley could be loose, but unlikely. "There’s still oil in the engine, might be low but it was full this morning and there’s no sign of a leak." Burning that much oil in 1 day would be very evident. Oil mixing with coolant although bad, wouldnt show a drop in oil pressure (although it could cause damage to bearings). The very first thing the OP should do is to make sure you have adequate oil by checking the dipstick (not just a little bit low, but so low its not even registering on dipstick) and then second, eliminate false readings from a potentially bad sender by hooking up an oil pressure gauge (or known good sender) to confirm whether or not its the sending unit. This is probably the most likely scenario assuming oil levels are sufficient. However... if oil pressure is confirmed to still be low with secondary sensor, then next steps are to check the other possible causes of low oil pressure which I have already mentioned. Losing oil pressure can be catastrophic even for short periods due to bearings now coming in contact with the crank journal and not having that thin layer of oil to float on. Hopefully that is not the case here. Keep in mind that when these cars are cold, oil pressure should be high (~4-5bar) and as the oil warms up, pressure drops (~2.5ish) due to the lower viscosity (see point 1).
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP Last edited by walfreyydo; 02-23-2021 at 12:18 PM.. |
With a loose crank bolt, you will lose oil pressure and the drive pulley for the alternator won't turn with the crankshaft. = no oil pressure and no electricity Check to see if the oil is actually low.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway) Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver |
