check oil light
HI, the check oil light in my car comes on lately after i've driven the 944 somewhere, turn it off, and start it up within about 5 mins. it will be off after it's sat for more than 5 mins or so. I've checked the oil levels and it didn't even need to be filled, and the oil was just changed 1200 miles ago. Should i change the oil again or is there something else that could be causing this? Thanks.
Old 04-30-2003, 07:16 AM
Petie3rd
Mrmerlin's Avatar
Hi, when does this happen at idle after it has reached operating temp?
What kind of oil was put in brand and weight?
Was the timing belt replaced recently?
Or the front crank/oil pump seal replaced?
Did a new factory oil filter get put on?
Could a wire be loose on the oil pressure sender? Possibly grounding?
Is the front crank bolt tight?
What year and how many miles does it have?
How hot does it run?
Please fill in as many blanks as possible...Stan
^^^ Stan ^^^ 2011 BMW K1300S Magma red
1988 S4 5 sp, Black / Black leather/ Carmel carpet
Old 04-30-2003, 07:57 AM
Do you mean the engine oil level light? If so the usual problem is the printed circuit on the dash. Either replace the circuit board or just check the oil regularly.
Do you mean the the engine oil pressure warning light? If so you probably need a new sending unit.
Next time, please let everyone know exactly what year and model 944 you are refering to.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 04-30-2003, 10:23 AM
88_944's Avatar
If you're talking about the engine oil level in the oil pan light than their is a sender on the oil pan. You might have a failing sender. If you just want to stop the light from going on, just pull the plug out from the sender.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 04-30-2003, 10:41 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Matter of fact, just unplug your oil pressure sender altogether and you never have to worry about being bothered by anoying lights again.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 04-30-2003, 12:08 PM
my apologies for not responding sooner, i have been away from my computer for several days. to answer your questions, the light will be on at startup, but sometimes the light will be off and will stay off the entire time the car is running; the oil is castrol gtx 20w50; timing belt was replaced at 102,000current mileage, 109,000, it was done in august of 2002;dont' know about the crank, oil pump seal replaced at 101,100; new oil filter at 107,800; don't know about wires being loose, where would i check for that?; it is a 1987 944s with 109,000; it runs cool, there is no overheating; the light that comes on is the "engine oil ight" the one with the little picture of the dipstick at the bottom of the gauge on the left side of the tach, the oil level indicator on the gauge to the right of the tach indicates oil level is at "5", the dipstick puts the oil level about halfway between min and max;i hope that answers all of your questions.
Old 05-02-2003, 08:32 AM
88_944's Avatar
"engine oil ight"
Ok, You have a failing oil pan sender. Just change it or pull the plug is you just want the light to stop.
My Black 944
Old 05-02-2003, 10:04 AM
what part would that be? "Oil Pressure Sender, 924S/944/968 All
F-606-203-01" or "Oil Level Sender, 924S/944/968 All
E-613-150-00" Thanks again.
Old 05-02-2003, 01:21 PM
88_944's Avatar
It's the "Oil Level Sender, 924S/944/968 All
E-613-150-00"
My Black 944
Old 05-02-2003, 05:06 PM
