breather hose options
924s 1987 auto
Hello,
On my 924s project I need the breather hose Part#944-107-187-01
For such a short hose its an expensive little guy. Looks like there was a cheaper option at one time by JL 56085 for about $26 but the oem one on pelican and ebay is around $65.
Has anyone found a bmw or volvo cross that would be cheaper? My only other thought is to just make one using 45 and 90 elbows.
Old 03-08-2021, 01:08 PM
You don't need one. Porsche came out with a bulletin that says to cap it where it comes out of the belt housing and cap it at the air box. I'm sure somebody on here has it.
Old 03-08-2021, 02:09 PM
not sure if we are talking the same part. this one comes out the oil separator towards the rear of the engine runs under the intake.
Old 03-08-2021, 02:31 PM
Your right. I was talking about a different one.
Old 03-08-2021, 02:33 PM
Check with Lindsay Racing maybe?
Old 03-08-2021, 05:25 PM
No luck with Lindsay racing. they use to have it but due to covid supply from china has wiped them out of the that particular one. Going to try and build one up. See how that goes.
Old 03-09-2021, 12:38 PM
I was able to find auto parts place that let me wonder around their warehouse and look at hoses. I think I might have found a solution for $14. I'll try to install this weekend and if it works I'll post the part#
Old 03-10-2021, 08:18 AM
Toofah King Bad
Rasta Monsta's Avatar
https://www.ebay.com/p/2156574888
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-11-2021, 07:23 AM
Pelican has the JL version for $27 in stock now. That seems hard to beat.
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 03-11-2021, 08:53 AM
looks like the one I found will work. I checked pelican but it was out of stock at the time. If this one causes problems Ill order from pelican
thanks
Old 03-12-2021, 11:57 AM
Here is the gates part I found for 14.99. It’s a bit short but I think it will reach.
Gates 19048 is the part number
Old 03-13-2021, 08:58 AM
