DIY Paint Correction?
Anyone here ever do a DIY paint correction? Sounds expensive to farm out...and sometimes iffy to find folks who truly know and/or care about this "craft" ("art?").
But there are a number of reasonably priced DIY kits floating around...and I'm tempted to give this a go. Anybody? Hints? Tips? DIY kit recommendations? Thanks! |
Driver
I remember this video from a while back
https://youtu.be/AX7t1hC2g6k I had Esoteric in New Albany, Ohio do mine at a very reasonable price. Good luck, GHEN
'87 944 |
I have done this and its super fun. However you need to be ready to make some mistakes. Might sand thru or buff thru. How bad is your paint?
This is what I use 2000 grit wet/dry sandpaper and sanding sponge. Rotary Buffer with a wool pad. You must use a rotary after sanding. Menzerna Heavy Cut Compound 400. This stuff is the best. It's not as heavy as its name implies but it cuts fast stays wet for a long time and finishes like a BOSS. You wont need a finer polish after using this stuff. But I do go after with a finishing foam pad and the Menzerna on a orbital. Then the final stuff is amazing. KLASSE All IN ONE. After quick washes squirt on some Meguiars Quick Detailer (Gold Class) and wipe off with a Costco microfiber cloth. BOOM! People at my work always ask me how I get my car so shinny. Mike G. |
Good pointers from others here, you may want to avoid wet sanding if you're new to detailing.
The main tool you need to get started is a quality random orbital polisher, these are beginner friendly and make burning through the paint -nearly- impossible, and a quality compound, and some sort of sealant or wax to follow up. You can get different levels of cutting pads and work your way from a heavy cut compound to a finishing polish. We sell Griots Garage polishers and compounds. They have extensive YouTube videos on all their products and walk you through polishing your paint. There is a plethora of other How-To videos out there and I definitely recommend people pick up a polisher and learn a new skill. |
I've also heard good things about the long throw orbital from the might Harbor Freight. I might even get one as my Porter Cable is kinda wimpy. If your paint is not too bad and you don't have orange peal that makes you NUTZ (like it does to me) then just use a clay bar first before you buff. There's tons of vides out there but serious get the Menzerna. It does have a pretty strong odor tho.
Lets just say you're German you love being German and you only by German tools. You also have a key to Fort Knox. Get anything from FLEX. BTW Menzerna is from Germany!!! hehe haha FLEX XC 3401 VRG DUAL ACTION ORBITAL POLISHER AND BUFFER Mike G. Last edited by Mike Goebel; 04-07-2021 at 07:48 PM.. |
Kessel run in 12 parsecs!
Color sanding? Your wording is hard to decipher. Is your paint faded and you are wanting to bring back the hue? Get some cutting compound, and a cheap orbital buffer and work the paint until its how you want it. Then Polishing compound for a shine. Then hit is with a good wax..
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
No its not! Must be a Texas thing
. Most call it color sanding but what if you are sanding clear. Anyway I usually color sand all my vehicles as I can't stand orange peel. Funny thing is that when I point out orange peel to most they don't even notice it. I guess that's difference between a retired furniture finisher and the everyday shmo.Mike G. Last edited by Mike Goebel; 04-08-2021 at 07:29 AM.. |
I’ve been polishing cars since I was a wee lad, or at least, a spotty teenager. There are many ways to make your paint look better, and not all need to be done with the bells and whistles demonstrated by the YouTube pro’s. I’d urge OK-944 to better define what he wants to achieve and maybe post some photos. Maybe a careful going-over with a clay bar, then hand polish and wax would suffice?
An old rule of any good detailer: start with the gentlest process, then work progressively more abrasive from there as is required to solve the problem at hand. In other words, many a good finish has been damaged by an over-zealous guy with a buffer in one hand and a big bottle of Heavy Duty Compound in the other. Last point: a certain amount of orange peel/texture is normal and how it came from the factory. When you “smooth” that out for a mirror-finish, you’re removing material, and what’s left is by definition thinner and more easily scratched/grazed. Top Tip: if you do want to dive into color-sanding and high-speed buffing, go practice on something more prosaic than your 944 ... Auntie Nellie’s 95 Chevy Lumina comes to mind. John |
Post a pic of your car. Make sure to get pix that demonstrate what the current condition of the paint is. Then do as I stated above. hahaha
Or you could be one of these guys that spends 80 hours with an orbital only to have a soso finish. Mike G. Last edited by Mike Goebel; 04-08-2021 at 04:01 PM.. |
Mike G. |
my $65000 BMW X5 has orange peel; that's the way it came from the factory. very slight orange peel is normal but probably not acceptable for the concours crowd. heavy orange peel from poor painting (like what I do in my garage) has to be wet sanded out ('color' sanding is old fashioned because paint jobs are now covered with clear coat
2002 Porsche 911 turbo 2007 Porsche Cayman S track car 1987 Porsche 924 Carrera GT tribute 2015 BMW X5 |
Seems a little optimistic to expect that your experience shellacking pine tables equates to understanding finish on a vehicle driven at highway speeds, exposed to all manner of weather, UV rays, and impacts. But, I'm not one to throw stones. I prefer to avoid chips, however, so I'll be keeping my peel. Back on topic, to the OP: OK, I'm sure you're no stranger to YT. There are so many great detailers out there. My favorites are AMMO NYC for technique/content, and OCD Garage for gear, accessories, and geek-out level info.
'84 944 5MT / '89 ANDIAL 951 / '92 MX-3 GS 5MT Projects: '82 928 5MT / '85 944 5MT / '92 740 Turbo Wagon |
![]() OK-944 - what type of paint correction are you specifically trying to accomplish? that will ultimately determine what you do.
Unless you painted her piano: ![]() This IS fun! Seriously, Mike, while you may want a mirror finish on your Steinway, you don't want one on your car. Unless it's a show car, it just doesn't make sense. For a driven car, a little bit of peel is advisable. You've got protection against the sun, washing/detailing the car, bugs, pebbles, etc. A surface with some peel will look better for longer, without having to constantly polish it (taking away more material). As John mentioned, it's also how the (every OEM) factory does it. Usually lower painted surfaces (closer to the ground, and road debris), will get heavy peel for the sake of protection.
Auto paint finisher too! And I have no idea who that chick is! But seriously when you plan ahead and finish your car for color sanding you put the right amount of paint on it. I know the factory stuff is probably a little bit thin and you can get one of those whizbang gauges to check it. But just take care of your paint.
This is the least level you should shoot for https://youtu.be/LhvgGvVWQDQ Mike G. Last edited by Mike Goebel; 04-08-2021 at 09:27 PM.. |
Mike G. Last edited by Mike Goebel; 04-09-2021 at 09:05 AM.. |
So why would an auto manufacturer, making hundreds of thousands of vehicles every year, program their painting robots to waste material? This stuff is expensive! Seems like your revelation could save them a lot of money, no? Or maybe, if they don't put peely goodness on their products, the paint jobs don't hold up, and they don't sell as many cars.
