Newer Late Alu Control Arm - Can't Rebuild?
Having removed the control arms from my ‘87NA project…I discovered that one of these looked a bit different (see on left in photo below) - featuring an additional hole and tab (with hole).
Digging a bit further about this version of aluminum control arm, I come to see that I cannot use the currently available ball joint kit…that in fact a ball joint replacement is impossible. Is this true?
Kind of pissed that of the two control arms, it is this later version which exhibited a torn boot. But the ball still looks good, and seems to operate smoothly - so I guess I’ll just add some grease and install a new boot and hope for the best. At any rate…as a heads up for those who might not know this, here are the two versions of the late aluminum control arm (newest, “non rebuildable” one on left):
Old 02-23-2021, 09:01 AM
Toofah King Bad
Rasta Monsta's Avatar
And what about the later piece renders it non-rebuildable? Different ball or something?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 02-23-2021, 10:25 AM
They are fully sealed from below with no epoxy or snap ring/way to remove the ball and socket from below as with the rebuildable aluminum arms.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP
Old 02-23-2021, 11:22 AM
In the Fires of Hell.....
kdjones2000's Avatar
I have posted about this multiple times over the years.
Left = rebuildable, Right = non-rebuildable:
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 02-23-2021, 11:26 AM
Stoneguy's Avatar
Just my two cents. I may be wrong but it almost looks like someone swapped out one of your control arms at some point with a 968 control arm. I notice the castings are slightly different and I believe the 968 control arms are NOT rebuildable.
1986 944 NA
2009 Cayenne
Old 02-23-2021, 12:20 PM
TibetanT's Avatar
That is what it looks like to me as well.
Doesn't the newer (1987 n/a --> on ) have a part number that starts with 951.XXX.XXX.XX ?
If my memory serves me right.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 02-23-2021, 01:44 PM
The new craze: Backdate Your Lower Control Arms with Steelies! $21 each and they fit either side! $10 Ball Joints! $40 for both bushings! You heard it here.
John
Old 02-23-2021, 05:00 PM
Toofah King Bad
John
Only works with early offset care.
Old 02-23-2021, 09:16 PM
dme dme is offline
The early 944 steel control arms would fit my 86 951?
Dan
86 Guards Red 951 (the best so far)
86 Black 951 (sold 12/31/09 PITA)
86 Guards Red 951 (sold in 7/15/00 (first love)
90 Plymouth Voyager, 2.5 Turbo 5 speed
Old 02-23-2021, 10:08 PM
All new arms are the 968 type.
Old 02-24-2021, 06:35 AM
Although I am almost 100% sure the 86 turbos are early offset, you will want to confirm whether thats the case.
One easy way to check (if you are running OEM wheels) is to look at which wheels you are running and run the part number (located on the back of the wheel) to determine what the offset is.
Phone dials (which is what came factory on the 86 turbos) come in both early and late offset, but its very easy to tell based on how much more "lip" early offset phone dials have over late offset phone dials without even looking at the part number.
Old 02-25-2021, 08:34 AM
Toofah King Bad
Originally Posted by walfreyydo View Post
although i am almost 100% sure the 86 turbos are early offset, you will want to confirm whether thats the case.
110%
Old 02-25-2021, 08:46 AM
dme dme is offline
110%
120%
I've always been sure of the offset, I just didn't know for sure whether the control arms were the same between the NA and turbo. I've heard rumors that they were interchangeable, but I never pursued it any further.
Dan
Old 02-25-2021, 09:50 AM
Yup...my car's history indicates that this control arm was switched out in 2002 - along with a phone dial wheel, so there must've been some kind of impact.
At any rate...bummer that this newer style arm cannot be rebuilt!
Old 02-25-2021, 11:28 AM
Toofah King Bad
I bet that something suitable is out there. Many newer cars have cartridge style ball joints. . .just need to find something that will fit there after some machining.
Such as:
Old 02-25-2021, 03:23 PM
I was wondering if 944 online dot com might have a solution and indeed they show rebuilt arms, 87 and up for $295 (and new for almost a grand each). They are good blokes at solving problems for these cars and have likely come up with a solution like Rasta suggested.
John
John
Old 02-25-2021, 05:59 PM
John, the 944 online folks are indeed great problem solvers - but the price you quoted assumes the exchange of a rebuildable core, otherwise add 200.00.
Rasta...was thinking also that there must be something out there like that - but I'd be leery of too much messing with aluminum at such a critical and stressed location.
Old 02-26-2021, 03:45 AM
So they wouldn't take your 968-style arm?
John
82 911SC coupe
Old 02-26-2021, 06:57 AM
Here are some options I found with a google search.
https://www.boostbrothersgarage.com/products/high-strung-944-tubular-front-control-arms?variant=34522469171244
https://www.ogracing.com/products/fabcar-racing-control-arm-4
Racer's Edge -- Racer's Edge Geometry-correcting A-arm NEW!
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 02-26-2021, 10:00 AM
John - generally to be accepted as a "core" the part in question must be rebuildable. But I'll phone Ian or Steve next week to discuss.
AZ - those arms look amazing (as well as high $$), but not necessary for my street-only driving. But thanks!
Old 02-26-2021, 02:21 PM
