Looking to buy a 944 Turbo...
Ever since seeing that episode of Monster Garage where they turn the 944 into a Golf ball shooter thing, i have been very interested in them. At first i thought they were a very "low class" Porsche and would be slow and not handle well. But after further research i have found out that i was very wrong.
So, now i am looking to buy one! I come from a family of straight line drag racers who think if it doesnt have a Chevy 350 (or larger) under the hood its slow. Right now i drive an 89 2.8L V6 Firebird that i WAS planning on dropping a 350 LT1 engine into it to get around 350HP. (while weighing a ton)
My local classifieds have 4 Porsche 944's in them for all under 10 grand. This is good, but i would like to keep it under 6000$ (so i can spend the extra money on performance parts)
Is it possible to get a good condition 944T for around 6000$?
Is there anything i should know before buying one?
What year is the best? (I heard 86 was)
I would like to get at least 300hp, what is the best way to get there?
I heard they are very reliable, but when something does break it is often costly, is this true?
Do Turbochargers often need rebuilding if never been done before?
Can a NA be converted to Turbo easily? (There is an 86 NA 944 in the classifeids for 2800$ its said to be in good condition)
Thanks in advance for answering my questions, i hope to join the Porsche comminity soon!
Old 04-30-2003, 12:33 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
Do a search, this has been discussed.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 04-30-2003, 12:41 PM
Scott R's Avatar
Re: Looking to buy a 944 Turbo...
Maybe, but most likely it will need something done to it right away, like belts or a clutch. Figure another $1500 in repair soon.
Yes, check out Clarke Fltechers site at this address:
http://www.clarks-garage.com/
No, not really. 87 and up had spring loaded cam belt tensioners, 52MM wheel offset, air bags and some had ABS. 88 Turbo S would be even better.
Chips, and a larger turbo coupled with a MAF upgrade.
Yes it's a Porsche not a camaro. Parts are more, and labor is always more. As for reliable, that may be based on you're initial investment.
Not always, it depends on the owner, the correct oil and driving habits will make the KKK 26/6 last forever.
Yes but it would not be worth it take the 2800 and add another 15k to it, (for your donar turbo car) and you still would not have all of the benefits of the Turbo. The 951 and the NA 944 are almost completely different cars when it comes to engine, suspension, and even certain parts of the body.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-30-2003, 12:46 PM
thamlin000's Avatar
944s and 944 Turbos are low-class Porsches. They are cheap to buy and are unfortunatly becoming a favorite among the high school aged crowd. These are not status-mobiles anymore.
They are, however, great sports cars. The 951 (944 Turbo) is probably the best all-around sports car for under $10k. Do you know of any <$10k sports cars that can do 0-60 in 6.0 sec, top out at 157 mph, out handle a 911, get 25 mpg, haul 4 people in pinch, and have a trunk large enough to accomodate an entire hood of a Ford Explorer w/ the rear seat folded (don't ask me how I know)?
Important:
Remember, Porsche parts are very expensive. You are better off spending more money to get a good condition 944 as opposed to buying a cheap one needing work.
Before purchasing, get a Porsche repair shop to inspect it. It could save you a ton of money.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 04-30-2003, 01:24 PM
andrewgoh's Avatar
Soft Taco,
Be patient...and the rare gem may turn up....
I bidded my time for a few months when I decided to buy a 951. I was finally able to get an 86 951 with 103K miles for less than $6,000. The price was low because I expressed concern about a broken exhaust stud. The shop that performed the Pre Purchase Inspection mentioned that it would cost $1,000 - $2,000 to drill out and change the stud. The P.O. agreed to absorb the cost, and we had a deal. By the time I purchased the car....it turned out the the broken exhaust stud was not a problem.....there was no exhaust leak and compression still measured at 150 psi. Here is the thread where I received excellent advice from the board:
New Baby in the Family...Need Help...
Thamlin000 pretty much summed it all up...good to have complete maintenance history...better to spend more on initial investment to get a good condition car, rather than pay later on parts.....and get a pre-purchase inspection....
I can confirm that parts are expensive.....I have 2 cracked fog lamps....this is just the lenses, not the whole housing.....and they cost $119 for each side (lowest price I could find)....
Good luck!!!
Old 04-30-2003, 03:44 PM
