What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
front SWAY bar/fuel system bleed
This weekend I am replacing fuel rail, Fuel injection seals, lower ball joints and suspension parts.
The question is: when I reinstall the front stabilizer bar, how do I gauge where it should be centered?
The current one is bent so it is getting replaced.. Maybe I should go visit So Cal?
Also, when the fuel rail refills with fuel, does the fuel system need to be bled or does the air in the system just get pushed through the cylinders?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 05-01-2003, 11:12 AM
Roger Hall's Avatar
Not sure but I have never had to bleed a fuel system. So I think the air will just be forced out the injectors.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 05-01-2003, 05:50 PM
Gordon - Are you referring to the front sway bar? Also, let me know how you make out with the fuel rail. If and when I get JXR944 pumping fuel I'd sure like to know what to expect.
Old 05-01-2003, 05:58 PM
Caper, yes, the sway bar. I could not edit the thread caption. I will post my results
Roger.. Thanks
3-924's (Sold)
1967-912 (Traded)
Old 05-01-2003, 11:57 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
you just don't love me anymore :~(
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 05-02-2003, 02:16 AM
AFJuvat's Avatar
The fuel rail will bleed itself, You will have to crank the car a couple of times to get it started.
Swaybar: On a stock setup, the bar should be self centering. It is usually easiest if you stick the ends of the pars in the control arm bushings first, and snug them a bit, then slip the bar (with center bushings installed) in the center brackets; then tighten everything up.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-02-2003, 02:30 AM
Swaybar: If you are installing new rubber bushings, I found it went easier if you make sure the swaybar is smooth and clean and put some talc on the inside of the new bushings.
Old 05-02-2003, 03:17 AM
GEEZ, you dont call, you dont come over, you wait three weeks to answer an email?? You dont offer me any copious amounts of adult beverage?
3-924's (Sold)
1967-912 (Traded)
Old 05-02-2003, 08:16 AM
