Alusil Cylinders
Hello All,
CAll me stupid, but i took apart my engine, and noticed that inside of my cylinders, there was some buildup. So I took a piece of 1000 grit sand paper with some brake cleaner and got it off. It didn't take much because there wasn't much of anything really. Anyways, my question is...My cylnders are alusil. and i dont know if i took the etch off when i took the sandpaper to them. Does anyone know how delicate the surface is??
Old 05-01-2003, 05:44 PM
Roger Hall's Avatar
What saying "If you have to ask dont do it." I think if the surface can stand up to the heat and friction under operating conditions you have not ruined it. I would wonder how long it will last though.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 05-01-2003, 06:11 PM
yeah..well i didn't even know that it was an issue until i read later that there is a coating on them..
Old 05-01-2003, 06:18 PM
Scott R's Avatar
So you have an SC and a 944? Jut curious...And yes you should be ok depending on how much sanding you did.
2018 Q5 Hybrid
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-01-2003, 06:45 PM
i have an sc..but i know that all you guys have alusil. so i thought i would ask you all. And i didn't really sand that much at all..just a couple of times around the walls is about it
Old 05-01-2003, 06:48 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
If you can determine the manufacturer of the cylinders for your car, most of them have US reps. That rep should be able to give you a definitive answer to your question, The Mahle US rep is here in Calif (within blocks of where I work). If it is Mahle, let me know and I will call them for you..
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 05-02-2003, 12:41 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
are you talking about above the space where the ring ridge would be on a cast iron block? I used sandpaper on mine too, to get the deposits off. rings don't ride on that area, so I don't think it maters. my 2&cent.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 05-02-2003, 01:22 AM
Mike B's Avatar
I doubt you did any damage if you only went around a couple of times...The silicon in the block is very tough stuff and that is actually what the rings are making contact with...
'86 951
'88 928S4 - the project
Old 05-02-2003, 12:29 PM
