1982 924 vacuum routing question
I have another Tech question.
What is the purpose of the ' ventury tube' that goes between the intake (vacuum) and boot after the fuel distributer.... It also 'y's off to the brake booster. I have always seen the brake booster directly connected to the intake manifold to get its vacuum source. I have had a hard time tracing out several vacuum leaks and found that if I plug this line with the 'ventury tube' my idle drops right down. |
awilson,
I'm interested in this , too, if it is that black plastic part. I wonder if some kind of check valve could be in it. drew1 |
| All times are GMT -8. The time now is 03:05 PM. |
