LinkBack | Thread Tools | Rate Thread |
Custom User Title
My passenger lock was completely stuck. Just for giggles I tried spraying wd40 into it and all over the mechanism, waited a minute, and like magic it works beautifully. If you've already tried that, tell me to shut up and get some real help
Ok so you removed the screw on the side of the door..... (where that screw is screwed in... gently push in at that spot, it sometimes keeps the handle from being pulled out) and then pull on the handle.....she should come loose....
She will pop out about 1-1.5 inches... then you can remove the plastic clip. You dont need to remove the panel from inside...
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Thread Tools | |
Rate This Thread | |
