Where can I get the tan plastic vacumm lines?
The local auto parts stores don't sell it. I can't even find them on ebizzle.
Old 05-01-2021, 09:28 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Paint them with plastic kote?
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 05-02-2021, 05:26 AM
option?
https://www.mcmaster.com/52035K14/
Old 05-02-2021, 09:06 AM
My Original Equipment lines are black
If you want to keep it original and are looking for the hard plastic/nylon small diameter lines I suspect they are nylon so it may be as simple as a search for generic nylon tubing in the diameter you need (I forget but I think it is 4 mm??). I am still driving with the factory originals and mine have always been black, so I'm not sure about the "tan" which may just be heat-aged clear? At one time I found the tubing at an auto parts store labeled "emissions" or pneumatic tubing. Sometimes listed as "nylon flexible tubing" or such.
If you want to also refresh the rubber connectors I believe the numbers are: 928-573-727-02-M269 for the "Y" connectors & the 90-deg elbow ones are 928-574-717-02-M58. I believe they are still available at Pelican. Good luck and have fun.
1988 Silver 924-S Original owner
Porsche 924S: The 944's cheaper, faster little sister.
Old 05-05-2021, 03:38 PM
I bought my plastic/nylon hose at my local porsche mechanic shop. It was black as my originals were. They also had it in white but not tan. Personally I have never seen tan hoses.
Old 05-05-2021, 06:38 PM
Tom, where are you located?
Old 05-05-2021, 06:39 PM
Looks like these guys don't have it but they are a great resource for many other things.
Blemetric
Old 05-06-2021, 05:35 PM
Choose from our selection of vacuum lines, including air hose, food and beverage hose, and more. In stock and Rubber. Plastic. Stainless Steel. Brass. Bronze Gray. Neon Green. Semi-Clear Blue. Neon Orange. Tan. Fluorescent Green.
NavyArmyCCU Login
Old 05-09-2021, 10:32 PM
