85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
which tranny will fit?
Can I put a tranny from a later car(87) in my early na?
Thanks!
-Ryan
PORSCHE: NOTHING EVEN COMES CLOSE
Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels.
95 Infiniti G20 dark red metallic-for sale soon
87 BMW 325ic Bronzit, stock(for now)
Old 05-04-2003, 09:40 AM
JH924S's Avatar
Send a message via AIM to JH924S
I see no reason for it not to fit, since people have put 951 trannys in NA's. so I would so almost definetly
1987 924S black on black , does it get any better?
Old 05-04-2003, 10:29 AM
JH924S's Avatar
I see no reason for it not to fit, since people have put 951 trannys in NA's. so I would say almost definetly
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
There are differences amongst the cars. Britwrench knows many of them as does So Cal. But I dont see either of them on line these days
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 05-04-2003, 10:44 AM
speedy007's Avatar
speedo connection will not match
88 944 bastard
Old 05-04-2003, 11:04 AM
85944na's Avatar
ok, I heard you can put any tranny in the early car because the speed sensor is on the wheel not the tranny, but you cannot put an early trans in a late car because no speed sensor. So as far as I can tell you just don't plug in the speed sensor on the late tranny and all is well, am I wrong?
Old 05-04-2003, 11:12 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
ae recently took an early model and put it in a late model. I have an '86 tranny in my '84. Mine was easier because I just disregarded the late model speedo fitting. The mounts were different, too.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 05-04-2003, 01:07 PM
85944na's Avatar
what mounts were different? Do I need new mounts?
Old 05-04-2003, 01:17 PM
todwic's Avatar
no, just save the mounts from your old transmission. The holes are the same, just the mounting system is different
'86 951
Old 05-04-2003, 05:59 PM
ae1969's Avatar
Send a message via ICQ to ae1969
you can use a late tranny on an early car.....
just ignore the electronic speedo connector....
the mounts are the same.....
The tranny mount changed but its backwards compatible.... but if you have your old mount use that...
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 05-04-2003, 06:00 PM
85944na's Avatar
cool, I'm pretty sure I'm going to put in an s2 tranny with lsd, will it also work? My mounts are almost brand new so I'll just reuse those. I can't wait to get this thing fixed.
Old 05-04-2003, 06:37 PM
I have a 951 tranny with cooler but not lsd if anyone is interested. Also have a tranny out of a 83.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 05-05-2003, 07:51 AM
I'm sure they fit but what it puzzeling is the input shaft on the early 016 is around 4" and the later ones around 5 1/2"...must be a lot of space in the coupler?
then the other question of the Audi 016 which has a shaft tip for the Audi's pilot bushing (but still measures around 5 1/2") shouldn't matter...anyone know?
Tom
Early '85 944
Old 05-08-2003, 04:29 AM
1.2gees's Avatar
Send a message via AIM to 1.2gees
All 944 transaxles are interchangable.
Mounts: Early mounts can be fitted to late cars.
Speedo: Late sender can be fitted to early cars.
There's no issues w/the coupler that I know of. Make sure your bit is in there before you start applying torque.
Ahmet
Cheers!
Old 05-08-2003, 10:36 PM
