fixed my air conditioning easily
a while ago i posted i was having problems with my air conditioning because when i turned the switch.. NOTHING happened. the fix was really easy, i took out the Haynes, checked the circuit diagram and then zeroed in on the #6 fuse.
just a little bit of sandpaper, and some battery post cleaner was it all needed. i put the fuse back in and the air worked just fine! just thought i'd share that easy fix :) obin |
Good one!
| All times are GMT -8. The time now is 10:30 PM. |
