-   -   Temp Switch 2 terminal or 3 terminal (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/10960-temp-switch-2-terminal-3-terminal.html)
Richard Foy 10-22-2000 10:10 AM
The other night I found my battery dead, then after a jump and charge, found my rad fans were running even with a cold engine. Ohm'd the switch and found short between + and 1 terminal. Anyhow, the real problem is , all I can get is a two termainal replacement...what's up?
