86' 944/No heat
I have a 86 944 that has no heat ...the blower works great ...its had a valve job over the last year...and I wonder if the vacume lines arent hooked up correctly ??? Thanks FM
Old 12-31-2012, 09:35 AM
uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
Check for vacuum leaks. Does your defrost work?
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 12-31-2012, 10:41 PM
same problem
Got the same problem. Not much of a problem in Phoenix, however I'm worried. Engine temp shows to be above the first hash mark. Car is running well. Defrost works but air is still cold, blower works fine. Any ideas?
Old 01-01-2013, 12:19 PM
PorscheChef's Avatar
One of the most common reasons for no heat in the cabin is a broken plastic clip up behind the heater controls, to the right side of you gas pedal. They are very easy to replace and having 3 944s, I keep a few on hand. Porsche 924S/944/968 Heating & Ventilation - Page 1
Other than that you could be lookind at a bad heater control valve, which is connected to you vacuum lines, also rather inexpensive. But, I would check this little plastic clip first.
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car)
Old 01-01-2013, 02:20 PM
AFM #725
Gawernator's Avatar
If the clip fails it should default to full heat, not no heat.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 01-01-2013, 02:49 PM
Oh, very true. I withdraw my above statement. I would still check the heater control valve.
Old 01-01-2013, 03:28 PM
I dont have defrosters either...???? Thanks FM
Old 01-01-2013, 08:44 PM
J1NX3D's Avatar
i have just got around to diagnosing my heater, also stuck on full, just this afternoon and yes its a broken clip. luckily for me i only have to pull my glovebox to get to it.
There's 3 per car, i could see only two though. the top arrow is the broken one.
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 01-01-2013, 10:55 PM
AFM #725
Gawernator's Avatar
Wait so that's where the second one is? lol I could only find one... and apparently there are three
Old 01-01-2013, 11:26 PM
J1NX3D's Avatar
i found the 3rd, its part of the blower door for the windscreen/dash vents.
(will post a pic soon)
im still getting hot air though, where is this heater control valve and what does it look like?
- 6 spd/LSD
Old 01-01-2013, 11:32 PM
AFM #725
Gawernator's Avatar
Ugh hope my other ones are okay -_- I replaced one
Old 01-01-2013, 11:39 PM
J1NX3D's Avatar
heres the 3rd one. this is on my LHD parts car so if you pull your dash instruments you would see this. if you can change your air to blow on the windscreen to the vents its working fine.
- 6 spd/LSD
Old 01-01-2013, 11:47 PM
AFM #725
Gawernator's Avatar
Okay thank god lol
Old 01-01-2013, 11:58 PM
J1NX3D's Avatar
is #9 what im looking for? couldn't see anything obviously wrong with the vacuum lines or those valves.
- 6 spd/LSD
Old 01-03-2013, 08:33 PM
Wow,..Great pic's guys Thanks FM
Old 01-03-2013, 08:54 PM
J1NX3D's Avatar
it could also be this heater valve, item #27:
- 6 spd/LSD
Old 01-04-2013, 02:04 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Heater control valve is the un numbered object (with the single vacuum line running to it and the numbers 3 & 8 over it) in front of the brake booster IN THIS DIAGRAM.
It is located between the block and the firewall, over the speed and reference sensors. Make sure the vacuum line from the heater control valve is connected to the "tit" on the firewall where the large coolant lines go into the cabin....right side below the head/cam housing.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 01-04-2013, 08:14 AM
89-944NA's Avatar
Simple me, when we were working on your heating system, I forgot to tell you to check to ensure that the vacuum lines were connected to the 2 "tits" located on plate on the firewall where the coolant lines go into the passenger cabin.
In the second drawing the mad924 posted, the "plate" is the sort of triangular piece below the a/c evaporator. Below the coolant lines (a bit hard to see), there are 2 small metal "tits" these supply the vacuum to the HVAC system
Semper Fi
Old 01-04-2013, 08:26 AM
AFM #725
Gawernator's Avatar
Oooh. I have always wondered what that plate was and where it is. How do I access it?
Old 01-04-2013, 09:20 AM
J1NX3D's Avatar
^ from your passenger footwell or the engine bay.
ok, that looks to be #27 in the other diagram. thanks!
- 6 spd/LSD
Old 01-04-2013, 02:28 PM
