Both cooling fans running
My car is a 1984 model with Air Conditioning. Per Clarks Garage, I thought that only the primary (driver's side) fan runs when triggered by the thermo fan switch and the passenger side fan runs only when the AC is engaged. On my car, both fans are triggered by the thermofan switch. Is this a fault or did someone modify the circuit sometime in the past?
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 07-09-2021, 06:03 AM
Patrick
pfarah's Avatar
Hi Chris,
The thermo switch will turn on both fans on high,as needed, while operating the car. If you turn the car off while both fans are running, the driver's side fan will continue to spin, albeit at low speed, until the temp is stable. That large green(ish) resistor behind the gauge cluster is responsible for the low running speed. Your car is operating normally my friend.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 07-09-2021, 06:29 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I had a similar issue with a newly acquired 944 turbo and found someone had put a jumper wire between the fan switch connector on the radiator causing both fans to run continuously.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-12-2021, 05:51 PM
Send a message via Skype™ to massive
I have an 84 square dash car too, but mine only has a single fan on the rad. Do you know how the 2nd fan is connected on yours, as I'd be interested in modifying mine to work with two fans.
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 07-13-2021, 04:34 AM
Toofah King Bad
Rasta Monsta's Avatar
Count your blessings and leave it as Porsche designed it.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-13-2021, 11:35 AM
Patrick
pfarah's Avatar
A single fan typically means that your car did not come with air conditioning.
Old 07-13-2021, 01:47 PM
