sasquatch's Avatar
Potentially stupid manifold question.
Through some reading, I find that the early 944's had the cast exhaust manifold. The later ones had the sheet steel one. My 87 has the early cast unit. It is not leaking or cracked. Would I benifit at all by going to the later unit. Car is already chipped.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 05-07-2003, 01:00 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
In short no.
The exhaust systems used on 944 series cars are really not restrictive at all. An example of this is 951s on stock headers/cross over pipes making over twice the stock levels of power.
Your NA has the same headers as the european cars that not only didn't have a cat, but had higher compression, and made more power. The late model headers should flow marginally better if any, but it wouldn't make a difference on your car. The changeover happened for durability reasons. The 2 into 1 section of the iron headers is a common spot of failure. If this happens however, the solution is neither complicated, nor expensive (fixed by welding, and since it's not stainless, most places can do this without a problem).
Ahmet
Cheers!
Old 05-07-2003, 01:25 PM
overkill's Avatar
Send a message via AIM to overkill
{1987}944S - (SOLD).
Old 05-07-2003, 01:55 PM
overkill's Avatar
Look at 1.2gees avatar starring down on my "I'm with stupid" image, LOL. Eck, I'm tired.
Old 05-07-2003, 01:57 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
That is the funniest thread title I've ever seen... I actually laughed
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 05-07-2003, 02:00 PM
overkill's Avatar
LOL!!! ****.
Old 05-07-2003, 02:04 PM
