New AFM
Received and installed AFM from Porsche dealer. New part has a hex CO adjustment screw for leaner or richer-old oem did not. I thought CO is carbon monoxide. What's up with this? Does this need to be tampered with and if so can I trial and error with it or does it need some sort of sophisticated equipment for a proper setting. I had hoped the O2 sensor would work in conjunction with the AFM. Thanks
Old 05-08-2003, 04:30 AM
AFJuvat's Avatar
the stock setting should be fine.
the CO adjust is used in conjunction with the O2 sensor to set the fuel air mix at a given RPM
The proper way to set idle requres the use of a CO monitor in the exhaust pipe. you adjust idle speed and CO level to fall within a set of parameters. think it is something like .8 CO at idle (800 +-40 RPM)
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-08-2003, 05:46 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
WOW, you bought a new AFM from the dealer?
Can I borrow some money?
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 05-08-2003, 06:21 AM
