Cracked Header
I was wondering if $300 to fix a cracked header was a decent
price...or if there is a cheaper way to fix it..
early 85 944
Old 05-08-2003, 11:55 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
if ya have a wire feed welder you can just weld it up. Not sure if an arc will work...it might. I'm pretty sure an oxy-acetanlyne would get the job done. Check the classifieds ont his site...I'm sure you can end up with a used header for about that price if not less.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 05-08-2003, 12:07 PM
robs944's Avatar
orignal header or aftermarket ?
either way that sounds kinda expensive......
you can usually pick up a set of stock used headers for under $100
check ebay they usually have a couple available or you can check out Ian at 944online.com
good luck
Rob
87 944 * 89 951
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car."
Old 05-08-2003, 12:16 PM
it is an original header.... the mechanic i went to said it was too close to the engine to weld...would a wire feed welder make a difference?
early 85 944
Old 05-08-2003, 12:33 PM
afx afx is offline
afx's Avatar
Send a message via ICQ to afx
for that price you could probably get an aftermarket header (bursch?). Also, I am not sure, but since you have an early 85 you probably have the heavy cast headers, you could always upgrade to the later lighter ones.
85.5 Red 944
Http://members.rennlist.com/afx
Old 05-08-2003, 01:02 PM
wow, I've never heard of the early cast manifold cracking, which one do you have? I have a good used set of cast ones if you're interested. I always thought they were bullet proof, usually the later tube ones crack.
Old 05-08-2003, 02:25 PM
rbt944's Avatar
If you are going to repair the stock cast manifold by welding, make sure you preheat the manifold before you weld it. Also, how much lighter are the later exhaust manifolds???
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 05-08-2003, 09:36 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Both styles seem to crack somewhat often. Most problematic ones are the 82-85 iron headers, these tend to crack @ the 2 into 1 section of the piping, on the upperside. There's enough room to weld them, if your mechanic isn't comfortable w/doing it, tell him to take it off. I don't think preheating is necessary but that's my opinon. 86 model turbos also crack, later ones included an expansion joint on the #1 cylinder to combat this.
The later manifolds are quite a bit lighter than the early ones. I don't think it'd be worth it to spend money on headers on any 944 except to upgrade to different fittings on a 944 turbo, if you're upgrading to a garret turbo. As I often say, US 944s share the same manifolds as the european cars, that had higher compression, and no cat. One can only conclude that they flow well enough. Any "gains" would then have to be just shifting the power band (as in tuning, and not actually making more power, ifyou were to look at a torque curve, the area under the curve on a 944 with aftermarket headers vs. a 944 w/stock headers whould be about the same).
Ahmet
Also, in the future, please use the search feature, this question was asked, and answered on the current page, as I type this.
Cheers!
Old 05-08-2003, 10:03 PM
In all my years, I've never heard or seen a cast one cracked, on the other hand I've seen about 4 of the later style n/a's do this, as for the turbo's, well that's a different story.
Old 05-09-2003, 07:54 AM
85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
Is yours cast? Mine isn't I don't know if mine has been replaced or what...
PORSCHE: NOTHING EVEN COMES CLOSE
Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels.
95 Infiniti G20 dark red metallic-for sale soon
87 BMW 325ic Bronzit, stock(for now)
Old 05-09-2003, 08:12 AM
If you weld it with a MIG or some other electrical welder, you'd better remove the chips. Or remove the header.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 05-09-2003, 08:19 AM
