Looking for Bushing and cover part numbers
I am replacing some of the myriad rubber covers, bushings, and plugs either missing or rotted away on my soon-to-be-back-on-the-street 944/2.
I have found and replaced the clutch inspection plug, the headlamp relay cover, and the clip for holding the O2 sensor plug behind the intake manifold. I'm looking for these parts but they aren't called out in PET:
You help is appreciated ;-)
1985.5 944 Base, Alpine White and Black Last edited by Autobreza; 07-15-2021 at 07:21 AM.. Reason: added info |
Found the brake line wear indicator grommet... it comes with a replacement wear indicator only and is not available separately.
Also fount the t/s protection cap. Still looking for the fog lamp connector protection cap. |
Glad you found the info on the turn signal connector cover. There's a good write up about sourcing and installing the boots: https://rennlist.com/forums/924-931-944-951-968-forum/1211842-turn-signal-connector-boot-2.html
1984 944 Zermatt Silver 1987 951 Flamingo Metallic |
PLP's Bushing Covers for wildlife protection are designed to reduce the number of outages Features; Documentation; Part Tables; Related Products.
Paycheckrecords Login Last edited by Carter9867; 08-11-2021 at 02:52 AM.. |
