-   -   A/C Mounting bushings (or delete a/c?) (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1099665-c-mounting-bushings-delete-c.html)
mattaebersold 08-10-2021 08:42 AM
931 A/C compressor seems bent inwards towards the firewall. And looking at it, it seems like part of the cause is the rubber bushings that mount the compressor to the bracket seem very worn out.
I'm worried that the AC belt will have too much wear since it will be pulled at an angle.
Some options that I'm considering:
1. remove the AC compressor. I don't mind not having A/C. I don't want to get under the dash to FULLY remove it, but at least the compressor and accessible lines in the engine bay. If that ends up happening, I can just run the main serpentine belt from the oil pump -> alternator -> water pump by themselves right? Like it's a separate belt on the 2.0 to connect the oil pump and the A/C unit right?
2. find new bushings
Looking online, I don't see anything other than used brackets with stock rubber bushings. Anyone know of a source for just the mounting bushings that get pressed into the bracket?http://forums.pelicanparts.com/uploa...1628610120.jpg
originalowner 08-10-2021 11:10 AM
Delete? I thought it was 108F there this year!
Is this your part number? 047260905C
mattaebersold 08-10-2021 01:29 PM
Oh interesting I see Auto Atlanta has those in stock. I'm assuming I would need 2 for the front and rear of the bracket.
thanks!
originalowner 08-10-2021 04:06 PM
It looks like it from the parts diagram I looked at. But, you should check that I looked at the right diagram for your car.
