Fuel Injector Seals
I have read in old posts that these can be picked up at just about any parts store. So do I just ask for fuel injectors seals or is there a specfic size or kind for our injectors?
1984 - Porsche 944 1994 Grand Cherokee 6inch Lift, 33" TSL'S |
you can get them anywhere. they're cheap.
obin ![]()
"Resale value": the phrase most often uttered by people who are afraid to admit they can't afford their car. |
I saw them on ebay for $2 a set
Edit: a set = 1 injector
Guys, go all the way and order a set of injector kits from Markus at http://www.blaszakprecision.com/
He has the proper kits that include the proper "hats" and even the small micro filters that go into each injector. If you are going to have them out, you might as well do the full job. It was less than $30 for the complete set including shipping from Can to the States. Jay
Sasquatch 1987 Porsche 944 1974 Porsche 914 "Don't retreat, reload." Sarah Palin |
I took out 1 injector, then I went to an auto store and I ask for the seals, then I check the correct size.
2 per injector Yes, you can buy at any autostore, you don´t need to buy oem item, in this case ! regards |
I will look into that complete kit sometime. As for now I am just going to get them at the local auto store, because they are going back in the car tomarrow. Thanks for the replies
little tip... get some Marvel Mystery Lube while you're at the shop. soak up the seals in this stuff before you put them back on the injector and re-insert the injector back into the fuel rail.
they will go in much easier with less fight or chance of ripping ![]() obin
What would Darth Vader do
I hope that was 30.00 canadian because I only paid 18.00 for a set of 4 sets.
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
