-   -   Where is the Power Window Relay? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/110115-where-power-window-relay.html)
zaxx81 05-09-2003 07:39 PM
I need help finding the Power Window Relay. It isn't in the manual or the shop manual. It isn't in the main fuse assembly. Please help, so I don't have to tear apart my car for one stupid relay.
Frank B 05-09-2003 10:08 PM
yes,,
carsontc 05-09-2003 10:10 PM
Found this in another thread...
"The power relay for the windows is under the dash by the instruments on the RIGHT side."
I guess it is somewhere around the ignition key area.
where as the other relays are under the dash by the instruments on the LEFT side with the fuses
btw...found the image of the fuse/relay box...of course the window relay isn't there anyway
bill underwood's site:
http://www.geocities.com/MotorCity/1760/earlyfusepanel.html
let us know what you find
zaxx81 05-10-2003 10:21 AM
Hopefully it is there, If not I'll just pull out the dash panels and follow the wire from the fuse.
zaxx81 05-10-2003 08:44 PM
See that is what I have been saying the whole time. I suspect the relay myself. I am having trouble findind it though. I have found four relays on the right under the dash, but they are not marked. Looks like I am going to have to tear the dash and console apart to follow the wire from the fuse.
carsontc 05-11-2003 06:47 AM
the wires going to the 'electric window control relay' are:
to coil:
86-black/yel
85-brown
contacts:
30-red
87-red/blue
take the fuse that keeps blowing and rig a 12v bulb in it's place. when this light goes out the short has been removed
pull one relay out at a time and see what happens
