Dash Lights
In forgot another problem I'm having with the dash and it is the lights. The three large lights in the bottom of the gauge cluster come on and dim properly with the switch. None of the little lights come on. There are some missing and a mounting screw missing so a previous owner was in here.
I have tested all the lights and they are good. I have measured voltage on the ribbons where each bulb is installed and there is voltage. As a matter of fact there is positive voltage on both sides with each bulb out which seems weird to me although I know there are different systems for lighting and German cars may use something I'm not familiar with. Any ideas |
A ground?
Sent from my SM-N960U using Tapatalk |
