Question Fly wheel Sensor
What do the two flywheel sensors do? They are marked BG and DG. the one marked BG is broken on my '83. (Don't ask, big time F-Up) Will the engine run with out, can I drive it to a shop to have it replaced?
TIA,
Mike D.
Old 06-23-2003, 07:36 PM
have a read:
step 6 of clutch replacement
http://www.clarks-garage.com/shop-manual/clutch-01.htm
more on how to replace here:
http://www.clarks-garage.com/shop-manual/ign-02.htm
and general info here
http://members.rennlist.com/dan10101/docs/SENSORS.doc
the reference sensor tell the DME unit when to start the spark and fuel injector sequence
the speed tell the DME unit when to turn on/off the fuel pump and the duration of the fuel injector pulse
among other things
Tom
Early '85 944
Old 06-23-2003, 07:55 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
I just replaced both of mine about a month ago, good luck... They are in about the worst location to work on.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 06-23-2003, 08:17 PM
Thanks,
I guess it's time to call a tow truck...
Old 06-24-2003, 10:20 AM
