-   -   It's Alive!! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/110283-its-alive.html)
interglossa 05-11-2003 12:20 PM
It's Alive!!
Well after a month of busy weekends and extensive internal surgery, my 944 has sprung back to life without so much as a sputter. I would have posted up to date pictures and comments, if i'd had a digicam and time. But, here's the skinny.
By some still unknown cause, the engine was puking out oil under the exhaust mani. So i'd decided i'd had enough. So i tore it all apart. Down to the bare block. What i found amazed me considering everything else i've discovered while tearing down other parts of the car. The engine was friggin spotless. The head's passages were clear and clean. Barely any deposits on the valves, and the tops of the pistons looked great. So i went ahead and resealed pretty much everything that was leaking.
Head gasket, front seals and everything from there on up. Gave it a good once over cleaning job with what i had.
Luckily the local porsche dealer has a really cool guy at the service counter who let me borrow the timing belt tool (p9201) for the afternoon. Pretty simple to use once you get the hang of it.
So to make this long story short, everything went back together to my amazement (first time doing a job of this proportion) and she as soon as fuel reached the injectors she fired right up. No smoke out the back only some from the manifolds as the remainder of the oil i spilled on it (oops) burned off.
One small detail however. I have to wait till tomorrow when my new brake booster check valve gets here. I broke the nipple off the old one for the hose that goes to the vacuum canister.
Anyhow, special thanks to everyone from the board that helped with my questions and thanks to Pelican, Zims and the guys at Haynes.
Can't wait to get it into my shop on tuesday to spray off all the oil on the undercarriage. Bloody mess that is.
Good day all.
ilikemy944 05-11-2003 12:28 PM
Whoohoo!!! :)
88_944 05-11-2003 12:30 PM
What a great feeling! :D
carsontc 05-11-2003 05:37 PM
nice to hear good stuff like this...congrats !
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
