Retrofitting Brembos on a 924s?
Is it possible to retrofit Brembo brake calipers on a 87’ 924s?
Thanks a bunch in advance guys.
Old 10-04-2021, 05:56 PM
9FF 9FF is offline
9FF's Avatar
Yes, but you will need to also replace your suspension (struts/spindles/hubs) to 1986 951 specification and you’ll need at least 16in wheels to clear the calipers.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 10-05-2021, 02:06 AM
Thanks a bunch! Will start digging into this for my next project.
Old 10-05-2021, 04:00 AM
Where are you located??
I have one side..
Old 10-05-2021, 09:49 AM
I have one side..
Im located in New Jersey.
Old 10-05-2021, 11:54 AM
Britain Smith's Avatar
I have both sides spindles and hubs from an '86 turbo.
'86 Turbo Front Spindle and Hubs
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 10-14-2021, 11:20 AM
You will lose your speedometer because there is not a hole for the cable in the later model spindles.
Old 10-14-2021, 01:20 PM
9FF 9FF is offline
9FF's Avatar
yep, that hole is a liability anyway, it just weakens the hub. Use a GPS speedo instead.
Mike A
Old 10-14-2021, 03:59 PM
You can have the spindle modified to make, we did that too mine.
Old 10-14-2021, 06:36 PM
