Lightbulb Thoughts on the new Lindsey Racing cams?
Looking at the tech specs on the ones for NA cars, they look astoundingly similar to the John Milledge s3-14 cams. If I remember correctly, those cams needed the DME FQS changed. Lindsey does not specify anything about this on the page, but the cams seem to be such a similar grind... maybe I'm looking too deep into it. Anybody planning on throwing one of these new cams in? They are going for cheaper than a Webcam is...
Old 11-07-2021, 11:08 AM
Northern Motorhead
wildcat077's Avatar
I have two of Milledge's cams , can't tell you the numbers off hand because his website is shut down , but one of them is a mild one with .473 lift and the second one which i use in my race car is the .502 lift unit which requires an aftermarket engine management.
The first one can be used with a stock DME but would benefit from dyno tuning in order to gain full advantage but the second one is a whole different story.
I wouldn't be surprised if Lindsey took over some of Milledges specs for their cams , although i always thought they were a Webcam vendor...
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 11-10-2021, 05:10 PM
Before getting a cam, get a modern ECU upgrade that eliminates the stock DME/AFM first.
Old 11-11-2021, 10:56 AM
Toofah King Bad
Rasta Monsta's Avatar
Far easier to lighten these cars and improve the suspension than to try and wring out more power.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-11-2021, 11:17 AM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Linsey racing has some pretty cool hop up goodies. I think they have 3 stage kits for more power on the 944 platform. Not many hop up shops for these cars.
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 11-18-2021, 07:15 AM
Tags
camshaft , horsepower , performance , thoughts
