1984 Power Windows
Electrical schematic for 1984 944 in Haynes Repair Manual 80035 (1027) and my on-line searches does not indicate a Power Window relay.
Does the 1984 944 use a relay and if so what is the relay slot position on the relay panel? |
Yes there is a relay, part number 321919505
Good luck, George Beuselinck |
The relay is located on the center console above the gas pedal, behind the "cone" shaped trim piece. It's the one with 5 pins, the other one with 9 pins is the radio/sunroof relay. The relay is a special one which goes on with the ignition, and stays on with the ignition off until a door is opened.
Early '85 |
Appreciate the immediate fdbk on the relay # & location. Now the task will be to get access to this relay location.
