1987 924S/944 Engine Compatibility?
As there have been no bites on my friend Cory's "free for the taking" 1987 924S...I'm now thinking that I'd like to harvest the engine (and dme) from this to rebuild and keep as a spare for my 1987NA 944. Any compatibility issues here? Thanks!
Old 12-30-2021, 06:14 AM
In the Fires of Hell.....
kdjones2000's Avatar
Wiring harness is different fuel rail is different, that's about it. I think the 924S has the larger oil pan with the oil level sender as well... not positive about that however.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 12-30-2021, 06:59 AM
OK944, what’s the interior look like? The hatch with smaller spoiler would also be worth saving (unique to 924 Turbo and 924S). Does the tach work? If yes, I’d be interested.
In other words, talk about parting it out and watch the vultures start circling, me included!
John
82 911SC coupe
Old 12-30-2021, 07:13 AM
Wiring harness is different, because the ECU mounts under the steering column on the 924S.
ECU is the same as the 87 944.
Fuel rail is the same as the 87 944.
Oil pan is the same as the 87 944.
Same engine type as the 87 944.
Good luck, George Beuselinck
Old 12-30-2021, 08:08 AM
So its basically a "plug and play" situation...in that I can use my current wiring harness with the 924S engine - routed to its current location underneath the kick board underneath the passenger foot well. Sound about right?
Old 12-30-2021, 12:59 PM
Sounds right.
Old 12-30-2021, 02:36 PM
