Toofah King Bad
Late Windshield, No Antenna
Anyone know a vendor carrying these?
TIA rasta
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Rasta, I just got a new windshield installed in my 87 924S, by Safelite. It was ca. $320 installed. Yes, Chinese glass. No antenna. I never even considered them despite them being on TV all the time. But they were actually the only vendor I could find … and I work in the car bizniss!
John |
Same here about 3 years ago I used Safelite and they sourced a no-antenna one for me.
Sent from my SM-N960U using Tapatalk |
I just called Safelite and they told me there was not a windshield for my 86. Anyone have a relevant part number?
Dan 86 Guards Red 951 (the best so far) 86 Black 951 (sold 12/31/09 PITA) 86 Guards Red 951 (sold in 7/15/00 (first love) 90 Plymouth Voyager, 2.5 Turbo 5 speed |
Zombie
Maybe a stoopid question here...but if my antenna window breaks and I need a new one - what if all that's available (or available at a reasonable price) are windows without antennas? - any work arounds for this to keep my radio happy?
Edit: Maybe run antenna wire out behind each side of the dash...up under the coverings of the A pillars, and maybe extend these even more up top? Might be an improvement over the existing window antenna? Last edited by OK-944; 02-10-2022 at 04:58 AM.. |
Good luck, George Beuselinck |
Zombie
Thanks for the link...but I would not want to cut a hole in my roof.
Google car window companies in your area and call them for pricing. I had a list two-page long!!!
This is what I did. Safelite was bet. 400 and 500 bucks. Some reached 1200. I finally found local company (in NJ) and they installed the windshield for whopping 200 bucks (without antenna). New. I re-installed side trim and caulk it with black window calking, because gaskets were "too thick" and were pushing out alum. side trim. This means, that there is a liberal layer of windshield adhesive. But, that's fine with me. |
Porsche dealers can still source windshields as a last resort there not cheap. last one i got quoted for with antenna was like 1400 canadian.. once installed etc probably 2k...
luckily i found one at my local shop for like 350 and i have salvaged 2 or 3 used ones for customers hiding away in my basement. hah good luck though
I went through this a few years ago when i had my car painted. My painter broke my front windscreen but paid for a new one. My window shop scratched my paint putting in the new one. Although it wasn't OEM they seemed to have no trouble getting a late windscreen, no antenna for my '86. I knew the integral antenna would could confusion so I just told them to get a 1992-95 968 one.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1071202-pandemic-project-porsche-944-a-6.html#post11114794
1984 944 Zermatt Silver 1987 951 Flamingo Metallic |
968 windshields don't have an antenna
... but in theory probably work... |
I just got off the phone with a glass shop in Dallas who says they have my windshield. $416 installed.
![]() My '86 has a few crossover parts from the early cars like an antenna in the front left guard like the early ones, so I didn't want the shop to get confused and buy the more expensive integral antenna one. The 968 has a roof-mounted aerial.
In the Fires of Hell.....
Keep in mind that there are 3 different versions of the late windshield: One for the non-airbag '86, and one or two others for the later cars with the air bag (extra layer of PVA in them). Should be in the $700 range. Maybe you get lucky
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Kessel run in 12 parsecs!
My windshield was cracked by a punk vandal, I called up a local glass fitter, got lucky they have a few in stock.
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
Custom User Title
You find a windshield, Rasta? I didn't see this thread till today.
I got one for my 951 last summer from these guys: https://www.genuineautoglass.com/location/ $413.25. Closest location to you is Lacey. I solved the antenna problem with a $23 antenna from Amazon. It's a flat, rectangular disc. You stick it on the windshield, out of the way, or on the back of the rear view mirror. https://www.amazon.com/gp/product/B07594YBJY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
