Zombie
Porsche Branded Oil…Cut To The Chase?
Anyone else here try out the “Porsche Branded” 10W50 motor oil that is supposedly precisely spec’d to our cars?
Yeah, I know…crazy expensive - but I’m seriously thinking that I’ll treat my recently rebuilt engine to a fill of this particular brew come spring, and I’d like to hear from others who may have some experience with this oil. Anyone?
Old 02-09-2022, 12:48 PM
Northern Motorhead
wildcat077's Avatar
You're most likely paying for the name and the fancy bottle.
For what it's worth , i've been using Amsoil Dominator 15/50 in my race car for years and it's a lot less expensive than Porsche branded oil and it has been proven to perform well under the toughest conditions ...
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 02-09-2022, 01:45 PM
Zombie
Looks like the Porsche branded oil is cheaper than the Amsoil Dominator (70.00/5 liters Porsche, 75.00/4 quarts amsoil) - but is your info different?
Old 02-09-2022, 03:01 PM
Mobil1 for me. I disassembled about 50 engines and could always tell the ones using full synthetic vs. the ones using conventional oils. Sludge=conventional; light brown color=synthetic
Good luck, George Beuselinck
Old 02-09-2022, 04:20 PM
You know, it's not like Porsche is running a refinery.
Early '85
Old 02-09-2022, 04:22 PM
944 S2
944 S2's Avatar
I know that OEM’s often formulate their own branded oil to meet their specifications. That being said I’m a big fan of old school Mobile one. I also have torn apart motors with many miles and the evidence is there.
Old 02-09-2022, 06:02 PM
Zombie
I’ve been running with Mobil 1 0W40 this winter (to below zero F in Vt.)…figuring that as my new bearing clearances are very close to what this particular oil specifies, that I’m safe using it, and so far, all seems well.
While I’d had good luck with Mobil-1 10/40 “High Mileage” oil in the past as a three-season (spring/summer/fall) motor oil - it was after I’d rebuilt my engine that it seemed that this oil might not be as appropriate…considering that seals and bearing shells are all new. In other words, the “High Mileage” formulation, which is supposedly designed to extend the useful life of older, possibly slightly hardened seals (according to Mobil literature) might actually be counterproductive for a recently rebuilt engine.
Thing is…I feel that a 10/40 formulation (synthetic) is about right for the spring/summer/fall climate here in northern Vermont - so if there is another 10/40 formulation that anyone here could suggest…I would certainly look into this.
Otherwise…I’m really wanting to get off of this “Motor Oil Merry Go Round,” and if this costs me a bit extra with the Porsche formulation…then so be it.
Old 02-09-2022, 06:09 PM
Most "Factory" Motors oils are made by a different manufacture. For instance. GM's Dexos is made by Exxon-Mobil.
Old 02-09-2022, 08:31 PM
Zombie
Then again...Porsche has been developing a synthetic fuel which the goal of relatively low emissions - and from what I can see they've had some promising early results with this. So perhaps the same minds were at work in the development of these (three) motor oils? If this is the case, then I'd feel even more encouraged to pony up the dough and give this oil a try.
Old 02-10-2022, 04:46 AM
Northern Motorhead
wildcat077's Avatar
I registered for the preferred customer program with Amsoil and they give you a pretty significant discount.Considering all the oil i use for the race car in one season as well as my 911 with a large Patrick Motorsports front mounted oil cooler , it's worthwhile for me.
Also , i used to use Klotz Tecniplate racing oil in the snowmoblies and dirtbikes but Amsoil satisfies my needs there too as they offer a wide variety of quality products.
Keep in mind , everything is more expensive here in Canada ...
Cheers
Phil
Old 02-10-2022, 01:24 PM
9FF 9FF is offline
9FF's Avatar
I bought a can just for the transaxles on it, no intension of ever using it. Fwiw I’m happy with Mobil 1 on newer builds and my trusted Brad Penn semi-synthetic on the original builds.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 02-10-2022, 04:01 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
LOL! Oil is oil, it comes out of the same place, folks pay for bottle and labels, if you want to pay more for the same chit, then more power to ya. LOL!
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 02-14-2022, 07:00 AM
