need help!!! 1986 turbo needle level
where should this needle read? a 944 turbo i might buy has the needle at about .75 and goes up to about 1.5 at 4000 rpms in first gear. is that low? a different one i was looking to buy was just about pegged at 2 right from the get go.
yup the stock is at 1.5 at boost....the other one is mostlike setup(chipped or a boost ctrl.)or it could even be more
I thought they were set at about 1.8 at full boost - factory setting? They fall off at higher rpms but under 4K they should be there.
should it be at .75 while idling?
.75 idling should be ok..it is only vacuum not boost....also what is the cars idle????
I agree with Lawrence because my '86 951 is totally stock (unless the previous owner put a chip in it but I'm pretty sure he didn't) and it goes to 1.8 and always has.
1.5 on the meter would be half a bar or about 7.5 lbs boost. Everything I have ever read says the 951 has 12lbs boost stock which would be .8 bar or 1.8 on the meter. [This message has been edited by T86951 (edited 11-30-2000).] |
If it is a stock gauge, it can't be trusted. One of the upgrades I am doing to my car this winter is installing a new boost gauge.
John |
