AFM bosh number
Hi!
Turns out my 944 has an AFM from a triumph TR-7, what is the correct bosch number for the original? My car is -87. If I search I find this number BOSCH 0 280 202 064 and BOSCH 0 986 280 041. I've read that there could be issues if its early AFM paired with late DME. Current afm has barn door adjusted to halfway open by spring, if I reset it the car will die. It is also running pretty rich so the original AFM would likely solve those problems Thanks in advance! |
0280202064 is the one that the factory used for the 87 944. it is used with the ECU number 0261200077.
Good luck, George Beuselinck |
Thanks for the info, ECU number is 0 261 200 076. So I take it that I need the other AFM?
0 261 200 076 is the ECU that came with the 85/2 944 from the factory. In this case, it will work with 0280202064
Kessel run in 12 parsecs!
British parts on a Geman car? Yikes!!! Just replace the part with a factory correct OEM part..
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
