Send a message via AIM to TheCooler
Noisy lifters?
Well whenever i give the engine gas now it goes "clickity clickity clickty click" and gets faster as the rpms go up. This is the noisy lifter sydrome? Before it was a very faint click and i could not hear it unless i had the hood open but now i can hear it when im driving. Should i invest in some ATF and clean the sucker out?
Any suggestions on products?
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-19-2003, 02:25 PM
Roger Hall's Avatar
Yes noisy lifters.
Yes ATF, not that big of an investment.
It is possible that you are low on oil or oil pressure check to make sure.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 05-19-2003, 03:01 PM
overkill's Avatar
Send a message via AIM to overkill
Dude, they shouldnt be that loud. Do what roger advised.
{1987}944S - (SOLD).
Old 05-19-2003, 05:46 PM
No I wasnt low on oil. I had about a little more then half inbetween the lines but now i filled it up to exactly full and still ticks. I will ATF the sucker soon ....exactly how bad is this for the car to have noisy lifters or is it just a sound problem?
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 05-19-2003, 08:51 PM
Roger Hall's Avatar
Not sure how much damage you can do, but people drive with them often. I would try to fix it ASAP. You can buy a bottle of stuff at the local auto parts store that you add to the oil. It worked for a freind on his dodge V6.
Roger Hall
81 924 N/A
Old 05-19-2003, 09:15 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
I will play the devils advocate here. Injectors click also! Just another thing to consider. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 05-21-2003, 06:19 AM
overkill's Avatar
NO NO NO, injectors do CLICK. Thats normal. Our injectors are very loud. If you can hear your lifters with the hood down and while driving then thats bad. Normally, they should soften out with a little bit of driving. Once the oil works it way in there they usually become very quiet. You might want to try and use a thin oil for awhile or use Juvats ATF/oil mixture for a bit to clean things out and get some lube where lubing is needed.
Old 05-21-2003, 08:26 AM
924Sman's Avatar
Thats what I am saying, They also click so don't confuse the sounds as lifters. Not saying the injectors are the noise that is being heard just a second source that makes a similiar sound...Sman
Old 05-21-2003, 09:53 AM
overkill's Avatar
Oh, dude,... i thought you were the guy that started the thread!!! Dude, I'm tired. WHA HA HA HA HA!!!
Old 05-21-2003, 10:14 AM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
I'd put my money on the injectors, check injector #2 they like to make noise (from what I've heard) then it stops spraying properly, then you get a power loss but you don't realize it right away because you're consumed by the ticking noise. Or your lifters are cruddy and I'm a SnapperHead for posting this.
My car is naughty
Old 05-21-2003, 06:09 PM
