Dual Filament Bulb Socket, Looking For
http://forums.pelicanparts.com/uploa...1650766070.jpg
This is one of the bulb sockets from the taillight assy. All sockets are the same, for single filament bulbs. I'd like to put a rear fog light in the left side taillight and can do so with the running light position if I can find a dual filament socket for the low watt tail light and a high watt rear fog light. Anyone come across something that will fit? |
would this brake light socket work?:
unique bargains part # A13050700UX0492 Socket Type: BAY15D, 1157 http://forums.pelicanparts.com/uploa...1650805948.jpg link: https://www.walmart.com/ip/Unique-Bargains-Double-Contact-3-Wire-BAY15D-1157-Type-Auto-Brake-Light-Lamp-Socket/196409919?wmlspartner=wlpa&selectedSellerId=571 |
I'm looking for a plug and play option first. But if nothing presents itself, I may have to resort to doing some actual modification to the mounting plate. Thanks.
Is the front turn signal / parking light a dual filament socket? If so, would this fit the rear? Also there is a open spot in the rear light panel and I have seen mods to add an extra tail or brake light, and this could be a fog light.
I already have the center (empty) light filled and plumbed into the brake light circuit. The outermost point would be a more appropriate location for a rear fog anyway, IMHO. I may just have to head to either a European specialty junk yard and poke around, or the nearest auto part store. If someone had a ready solution that would have been great. |
| All times are GMT -8. The time now is 11:57 PM. |
