Cooling fan resistors
Hey all I need some help to know if my fan resistors are good. This is the two configuration type with 0.9 ohm resistors. The wires are getting bad and need to be redone but I am not sure about the resistors. I used a multimeter with each disconnected and got a reading of 4.8 ohms on one and 3.0 on the other. Being the novice that I am, I do not know if that is OK or not. So do I keep or get replacements?
Old 05-06-2022, 08:15 AM
I believe the Clark's Garage has the answer. Check there.
Sent from my SM-S908U using Tapatalk
Old 05-06-2022, 08:28 AM
OK thanks, if I am reading it correctly, then I need to replace both of them.
Old 05-07-2022, 06:04 AM
