Send a message via AIM to Bladefire
Possible vacuum issue?
Hey everyone, I just picked up an 86 944 with a near-perfect body and OK mechanicals and it's got one over-bearing problem at the moment. The car idles very rough at around 8-900rpm and will often times dip to 'near unrunning' states (aka it almost stalls), and sometimes it stalls outright. Power seems to be sapped anywhere below 2000rpm, but above that...runs like a champ.
I've read about a lot of folks here having vacuum line problems...could this just be another one?
Old 05-24-2003, 07:04 PM
Roger Hall's Avatar
Could be any number of things, but mabye the vacuum gremlin found a new vacation home.
You need to preform a basic tune up and post back.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 05-24-2003, 07:19 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I would check positioning sensors. make sure they are tight.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 05-25-2003, 01:44 AM
turbohead7's Avatar
Porsche Crest Rough Idle
Couple scenarios. First check the airbox/air filter. If you suspect a vacuum leak, idle the engine and squeeze that rubber boot going from the air filter to the throttle body while looking for a change in the idle. You may find that it's dry-rotted or split. Check the idle stabilizer for proper operation. Lastly check fuel pressure. There aren't a lot of vacuum lines on your engine, the ones you do have are made of a durable hard plastic and are easily traceable by tugging them. Check the rubber fittings.
Even though I drove a GT2, I still love my 944.
Old 05-25-2003, 10:48 PM
