fuel injector hats
I bought a set of fuel injector seal kits for my 87 951 and the plastic hats in the kits are longer then the hats on my injectors. I bought them from Pelican and they said they only carry 1 kit. Has anyone else had this problem? I put the larger hats on but my car is running horribly. My old hats fell apart when I tried to take them off so I couldn't reuse them.
I had that problem. What color are the hats? I got yellow caps from somewhere, I use a sharp drill bit to cut a nice taper in the top of the injector cap to promote a good spray pattern. Here's what I did,...
Here's the new cap, notice the small hole,... Here's the modified cap, notice the nice taper,... Here the OEM cap,... I gave the new cap a nice taper so the the fuel once shot out of the injector, doesn't hit the hole or side or the hole. Keep in mind that the cap is only to protect the tip of the injector, thats it. I used these modified caps in my "S" and she ran just fine.
{1987}944S - (SOLD). Last edited by overkill; 05-25-2003 at 06:41 PM.. |
Thanks very much! I will try that. The caps are yellow as well.
Cool.
{1987}944S - (SOLD). |
