hankster's Avatar
Unhappy relays
Need some help! I have faught the postion of the relays on my 1983 944 since purched last year. They were mixed up, after market and some wires broken. Repaired wires and have be playing relay swap since then. Have some functions working. I need to know what relays go where. Got the fuse/relay posting, but doesn't help with relay postion. I need what relay pinouts go where. The pin numbers that are on the relay pins and relay numbers should show me where if I had the pins numbers on the relay sockets which they don't . Is there a list somewhere that shows the pinout numbers for the relay scokets? example: one relay has pin numbers on the bottom of the scoket where the pins are...85,86,87, 30,33. If if I had the socket pinout it would be done already.
Need help
Hank
Resist Assemiliation, Don't be Borg!
Hank
Old 07-28-2003, 09:16 AM
SoCal Driver's Avatar
Know of a fellow that cut the entire fuse and relay block out of his wrecked 84. Might be able to get it from him complete with the wire stubs. Sure would tell you what goes where.
That and the factory electrical schematics in the factory manuals.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-28-2003, 10:13 AM
vott does ziss do?
ronin's Avatar
what car?
Old 07-28-2003, 10:49 AM
The "wrecked" car.
Old 07-28-2003, 11:39 AM
vott does ziss do?
ronin's Avatar
lol, i guess that all depends of what it wreaks
vott does ziss do?
ronin's Avatar
I guess I should have specified, I meant what car does hankster mean
Old 07-28-2003, 11:40 AM
