-   -   Removing shift knob (968), no clip? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1124763-removing-shift-knob-968-no-clip.html)
Cpl55 08-17-2022 07:40 AM
Hi all, I’m replacing my OEM shift knob with a new (OEM) one… I’ve done a search and have found directions for the 944, but they all show a metal clip at the bottom of where the knob joined the shifter. Mine has no such clip… how do I get this thing off?
http://forums.pelicanparts.com/uploa...1660747144.jpg
944 Ecology 08-17-2022 07:43 AM
The clip is hiding under the rubber boot. There is a slight hump there. Pull the rubber boot down and you will see it. (or pull the rubber up from the console until you see about 1/2 inch of the shift knob.)
Cpl55 08-17-2022 01:14 PM
That did it, thank you SO much, George! :)
Ernie944 08-18-2022 03:26 PM
Easy when George tell you how to do ithttp://forums.pelicanparts.com/support/smileys/wat3.gifPic of my mod shifter in my ex 968.http://forums.pelicanparts.com/uploa...1660861333.jpghttp://forums.pelicanparts.com/uploa...1660861418.jpgTake care Cpl55 & enjoy your 968 ,they were one of the best car to come out the Porsche factory....:D
