david944's Avatar
headlights
I have seen some pictures of 944's with the headlights up but not on. The only way mine are up is if the lights are on.
Is there a way to keep them up without any lights on?
Old 12-30-2000, 05:21 PM
With the ignition on, turn on the lights. Then turn the ignition off. The lights should stay up and off.
I turn the lights on, turn off the ignition, and disconnect the battery ground when it's time for new bulbs.
Nick
lights are about all that works on my 931 right now.....
Old 12-30-2000, 05:45 PM
Location: Las Cruces, New Mexico, United States of America
Send a message via ICQ to Porsche 951 Fanatic
Or with the car running... or off.. you can turn on the headlights then just put it to the park lights.... I believe that is how i used to do it on my car... it was a 85.5 na944 - the headlights would go down when the park lights were turned off
Old 12-30-2000, 05:49 PM
The way to keep the lights up but not on are achieved two ways:
1. Turn your light switch all the way to the on position, then turn it back to the parking light position...this means having to drive with your parking lights on.
2. Disconnect the motor to your headlights and use the manual headlight knob to place your headlights to the up position.
Old 12-30-2000, 05:51 PM
david944's Avatar
thanks to all replys, That just had me wondering.
Old 12-30-2000, 07:03 PM
The headlight motor has a manual turn screw under the rubber boot - check your owners manual. However, you must pull the motor fuse in order to turn this manually! Otherwise it will engauge and automatically close again.
Old 01-02-2001, 09:04 AM
Just curious, other than changing the bulb, why do you want to do this?
Dave
Old 01-02-2001, 02:34 PM
Banned
I "get-em up" so that I can wash off the bugs and detail the black plastic areas.
Old 01-02-2001, 04:41 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
If you can flick the switch, with the headlights as high as you want them, you can force air into the engine comp at speed...
Ahmet
It's all the driver...
Old 01-02-2001, 10:33 PM
